jdimailig
Aug 01, 2020Follower
CAX80: Modem is offline - Please check RF connection
Netgear Nighthawk AX8 (CAX80) ISP: Comcast (Xfinity) Hardware Version: 1.01 Firmware Version: V1.1.0.36 Cable Firmware Version: V1.02.08 Trying to get the new CAX80 up and running, replacing ...
Sep 27, 2020Guru - Experienced User
Any progress on this? Or did you give up?
jdimailig wrote:Netgear Nighthawk AX8 (CAX80)
Trying to get the new CAX80 up and running, replacing my C6300 modem router. Unfortunately it's having issues going through the activation process.
My old C6300 still works and I remember it had working out of the box with my Xfinity service, so a little bummed that this wasn't as seamless as I hoped. For the CAX80, the online activation through the Comcast Xfinity web interface didn't work for me, nor did activation through contacting their tech support.
All I get is "Your modem is offline. Please check the RF connection."
The upstream/downstream lights were able to turn solid white, but the online light would never stop flashing. I'm told by Netgear tech it means that it was able to get a link, but unable to get assigned an address, so the issue is probably on Comcast side.
Has anyone seen this issue? I've tried both contacting Comcast (to see if they can activate by giving them the MAC address) and Netgear (to verify if they had any insight as well) for support but there was only so far I could get with the low level of support they are able to provide. Maybe because it's the weekend, but I didn't feel very confident that the support was that great.
I'm just confused because I figure if my old modem still worked (and still does), there shouldn't be anything preventing the CAX80 from getting activated either. Unless there is some difference in signal requirements between the two modems?
I've switched back to my trusty C6300 temporarily until a solution is found. Getting an Comcast Xfinity tech to come by tomorrow but am hoping there was a way to avoid it, or at least an idea of what the issue is before tomorrow, cause not knowing is driving me a little crazy.
I figure if this doesn't get resolved, I'll just refund it and refrain from upgrading my internet setup for a while.
