doug2222
Jul 16, 2021Aspirant
CAX80 Modem Router, Mult-Gig Ethernet port connected to RAX120 router causes internet disconnects
I have a Nighthawk AX6000 DOCSIS 3.1 WIFI 6 Cable Modem Router (CAX80), connected to a Nighthawk AX6000 WIFI 6 Router (RAX120) via the Multi-Gig Ethernet ports on both devices. problem, any wired ...
doug2222
cable is probably a cat5 so i will need to get a 100 footer and replace it.
mode i will have to check. think its router on both units.
cable doesnt matter as others having the same problem have had Cat6 cables and their routers had the same symptoms after firmware update 2.1.1.4
Jul 16, 2021Guru - Experienced User
Ya CAT5 isn't supporting of anything over 100Mpb per spec. At least 5e but CAT6 is best.
Lets check modes on the CAX. Would be a good test to see if modem mode on the CAX and RAX in router still happens.
I may put my CAX back online and take another look at this as well.
