doublegs
Mar 07, 2021Guide
CAX80 Multi-gig ethernet port dropping
I've upgraded to the CAX80 to take advantage of Xfinity's new 1200mbps speed. My PC has a 5gig ethernet port. I've already spent over 2 hours on the phone with NETGEAR support - with no resolution be...
Mar 07, 2021Guru - Experienced User
What is the brand and model# of this 5G adapter in your PC that your connecting to the port?.
Be sure the drivers for this adapter is up to date.
Does a 1000Mbps network adapter do the same thing? You might try a 2.5Gbps adapter instead...
