doublegs
Mar 07, 2021Guide
CAX80 Multi-gig ethernet port dropping
I've upgraded to the CAX80 to take advantage of Xfinity's new 1200mbps speed. My PC has a 5gig ethernet port. I've already spent over 2 hours on the phone with NETGEAR support - with no resolution be...
Mar 08, 2021Guru - Experienced User
Like FURRYe38 says, check the card in the computer.
I had a qnap 2.5/5/10g card that has been nothing but problems in my server/media pc.
I could pull full speeds but my streaming would freeze/drop consitently. Opened a support case with qnap and had a few beta drivers we tried and it kept happening. I finally switched to a tplink 10g card and its been rock solid since.
Every once in a while I pull the old card out and update drivers and test it and its still been sketchy.
doublegs
Mar 08, 2021Guide
Please review my reply to him above and let me know your thoughs. I really hope it's not my $400 motherboard.... :smileyfrustrated:
- plemansMar 08, 2021Guru - Experienced User
Do you have any other 2.5/5/10g devices?
Its tough to tell which one is causing the issue when you've only got 2 devices.
I ran into the issue when I had mine because I only had 2 devices as well. I did a little research with mine and see quite a few issues with the card so tried a new add in card.
I can't tell you what to do though.
If you don't have another 2.5/5/10g device, know anyone's you could borrow to test?
- doublegsMar 08, 2021Guide
Unfortunately, that is my only device in the house that supports above 1gbps. Just to confirm - the port works fine in 1gbps most, but as soon as I go to multi-gig that is when it will have intermittent connection.
Should my setup include a switch in your opinion? I have the 1200mbps plan from xfinity but can pull about 1400mbps.
Would introducing a switch be recommended in this scenario?- plemansMar 08, 2021Guru - Experienced User
Not sure what direction to point you in at this point.
Multigig switches are a bit expensive right now.
An option?
Amazon has a fairly generous return policy. You could try a different network card to see if it is indeed the card or not.
