All2surreal
Sep 18, 2023Aspirant
CAX80 Multigig Port Behavior
Hi. So this forum is full of the issue in the subject line. After reading hours of comments and discussions I understand that this multi-gig port is essentially not stable, period. I'm a Senior Sy...
- Sep 22, 2023
Alright so time for an update and with some great news! After downloading the latest Intel NIC driver installer package from Intel's website and and installing it, I'm happy to finally say this problem is 100% gone. I will note however, that with using the Amazon cable the problem comes back, but on my six year old cable the connection is rock solid. So, now I have to believe that the Amazon cable is either not compatible with my NIC or the router or both. I did Fluke test it and it's completely fine and rated at 10Gbps. I'm returning it to Amazon and have purchased a new 6A STP one: https://www.amazon.com/dp/B00HEM61KA?psc=1&ref=ppx_yo2ov_dt_b_product_details
More updates to come...
Sep 18, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Is the CAT5E UTP? There is no such thing as CAT6E.
For any connection rates 2.5Gb or higher that's beyond 1Gb, CAT6A STP is recommended. Shielded Twisted Pair.
I've been using my CAX80 with it's MG port and have not had any issues connecting to it with a PC or with MG supporting routers connected to the CAX80 MG port. Yes, I use CAT6A STP cabling.
All2surreal
Firmware: 2.1.5.2
Attached is the pic of the 1000ft spool of CAT6E UTP 23AWG network cable I used to make my 109ft cable for home. Again, the network cable I made for home is nearly six years old and has been rock-solid. It's always provided 2.5gig speeds with the CAX80 and my gaming PC and still does. It's the network cable from Amazon (link in prior post) that brought about the problem with the port dropping while on this Amazon cable.
I will test the Amazon cable with the Fluke tester when I can get ahold of it at work later this week and post back the results.
Concerning your reply...how precisely did you first experience this problem?
