JJackson914
Oct 20, 2022Follower
CAX80 Newest Firmware Doesn't Work (2.1.4.2)
My home's Nighthawk CAX80 doesn't work on the newest firmware (2.1.4.2). Whenever it automatically updates to 2.1.4.2, nothing is able to connect. The WiFi signal is able to be seen on my devices, bu...
Oct 20, 2022Guru - Experienced User
Did you factory reset the modem and setup from scratch after v4.2 was loaded?
