JJackson914
Oct 20, 2022Follower
CAX80 Newest Firmware Doesn't Work (2.1.4.2)
My home's Nighthawk CAX80 doesn't work on the newest firmware (2.1.4.2). Whenever it automatically updates to 2.1.4.2, nothing is able to connect. The WiFi signal is able to be seen on my devices, bu...
vdelvalle11
Oct 26, 2022Tutor
Have you found a solution to this? I am having the same issue at the moment.
- FURRYe38Oct 26, 2022Guru - Experienced User
Did you factory reset the modem and setup from scratch after v4.2 was loaded?
- vdelvalle11Oct 26, 2022TutorYes, I did a complete factory reset after the update. The device still has the issue after any reboot. Anything else you can think of that may help?
Try reverting back to prior FW version...
