JJackson914
Oct 20, 2022Follower
CAX80 Newest Firmware Doesn't Work (2.1.4.2)
My home's Nighthawk CAX80 doesn't work on the newest firmware (2.1.4.2). Whenever it automatically updates to 2.1.4.2, nothing is able to connect. The WiFi signal is able to be seen on my devices, bu...
Oct 26, 2022Guru - Experienced User
Did you factory reset the modem and setup from scratch after v4.2 was loaded?
vdelvalle11
Oct 26, 2022Tutor
Yes, I did a complete factory reset after the update. The device still has the issue after any reboot. Anything else you can think of that may help?
- FURRYe38Oct 26, 2022Guru - Experienced User
Try reverting back to prior FW version...
- vdelvalle11Oct 28, 2022Tutor
I have downgraded but it upgrades over night. Leading to the same issues.
- FURRYe38Oct 28, 2022Guru - Experienced User
Ok. I'll pass this on to NG for review.
