dbmdude
Aug 24, 2020Aspirant
CAX80 NightHawk AX8 Cable Modem Has no QoS settings
I cant select the proper model as mine is not in the list; nor can I select a location because there is NOT one for Nighthawk AX8 Cable Modem. Anyway is there any chance that the QoS settings can...
Aug 25, 2020Guru - Experienced User
dbmdude wrote:I cant select the proper model as mine is not in the list; nor can I select a location because there is NOT one for Nighthawk AX8 Cable Modem.---might help to be in the right forum for posting for modem/router combo device and not mobile routers. but the CAX80 doesnt' look like its been added there yet. https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Anyway is there any chance that the QoS settings can be enabled on this device? When I first got the device the firmware was 1.1.0.36 and it had QoS menu options (although I never looked at them) and when I upgraded the firmware to 1.1.0.41 there is now NO QoS settings AT ALL.---I wasn't aware it had QoS at all. And I've had it since release day 1. I have to admit I never really looked for it since I'm on a gig plan.
Somwhere I found in my search that I needed to get the Orbi app... but when I get the app and try to connect to this cable modem it states not applicable for my device.---You don't need the orbi app. You need the nighthawk app. if you're on android: https://play.google.com/store/apps/details?id=com.netgear.netgearup&hl=en
Why cant they make it so I can downgrade my cable modem to 1.1.0.36 so I can have QoS again?????????
I hate this.
The CAX80 has firmware for both the modem side and the router side. Currently they're both controlled by the ISP. The router side is supposed to be getting enabled for end user updates but I haven't found any posted yet.
Something else is what speeds do you pay for?
If you're on a plan with speeds >250mbps, then qos isn't recommended.
vkdelta Any idea if QoS is getting added or if Netgear will be posting the router firmware so end users can update/downgrade the firmware?
- vkdeltaAug 25, 2020NETGEAR Employee Retired
there is no QoS feature on CAX80 and no plans to add it.
in .36 there was QoS Menu but had only speedtest option in it. It was renamed to just speed test in newer FW.
So,there was never a QoS feature on .36 FW.
- dbmdudeAug 26, 2020Aspirant
Can somone at NetGear (possibly vkdelta ) get the official reason from the engineers as to WHY the QoS settings were removed from the router side of this cable modem??
THANKS
- vkdeltaAug 26, 2020NETGEAR Employee Retired
There was never actual QoS settings or feature (except Speedtest was labelled as QoS).
It was renamed to Speedtest in newer FW.
- dbmdudeAug 25, 2020Aspirant
plemans wrote:The CAX80 has firmware for both the modem side and the router side. Currently they're both controlled by the ISP. The router side is supposed to be getting enabled for end user updates but I haven't found any posted yet.
Something else is what speeds do you pay for? I pay for COMCAST 500mb but for reasons I cant explain (as I tested this). I asked the three users in the house what they were doing at the time after a speed test showed 47mb; they said they were streaming video; I then asked all of them to pause video and I would do a speed test and I got 477mb; then I asked only one person to resume and I got 53mb. I know that video streaming does not take that much bandwidth SO i needed the QoS setings to prioritize the bandwidth usage so my streaming on the main TV in the house is not interrupted by "whatever my son is doing that takes 424mb".
I do not understand the above statement because I use it to control the bandwidth so a single person cannot hog it.
vkdelta Netgear really needs to consider adding QoS back in. I really need it.
- FURRYe38Aug 25, 2020Guru - Experienced User
The only time you should be speed testing is when nothing is streaming or downloading. This gives incorrect speed results. It is normal to see slower speeds especially if others are doing something that usues up bandwidth. I have two xbox consoles connected to mine and don't see problems while others are streaming or doing something on the internet. Though I have 1Gb ISP service as well.
