dbmdude
Aug 24, 2020Aspirant
CAX80 NightHawk AX8 Cable Modem Has no QoS settings
I cant select the proper model as mine is not in the list; nor can I select a location because there is NOT one for Nighthawk AX8 Cable Modem. Anyway is there any chance that the QoS settings can...
vkdelta
Aug 25, 2020NETGEAR Employee Retired
there is no QoS feature on CAX80 and no plans to add it.
in .36 there was QoS Menu but had only speedtest option in it. It was renamed to just speed test in newer FW.
So,there was never a QoS feature on .36 FW.
dbmdude
Aug 26, 2020Aspirant
Can somone at NetGear (possibly vkdelta ) get the official reason from the engineers as to WHY the QoS settings were removed from the router side of this cable modem??
THANKS
- vkdeltaAug 26, 2020NETGEAR Employee Retired
There was never actual QoS settings or feature (except Speedtest was labelled as QoS).
It was renamed to Speedtest in newer FW.
