SuperFrustrated
Mar 31, 2023Aspirant
CAX80 no 5G...light solid
I received a CAX80 as a replacement for a bricked CAX30 due to the firmware issue.....the 5G light is lit but steady and network will not populate on any device....If I place my cell phone directly o...
Mar 31, 2023Guru - Experienced User
Does a factory reset change anything? Press the reset button for 10 seconds then release.
Has the modem worked at all since you got it from NG?
- SuperFrustratedMar 31, 2023Aspirant
No...I have reset the modem 5x's....been thru numerous tests with support and still...solid light but no 5g
Yes..modem worked till 1am when a new firmware was pushed...all connected devices went offline and when I awoke...I realized the issue when the laptops wouldn't connect(I work remote)....
Comcast...not a comcast issue
- DarrenMMar 31, 2023Sr. NETGEAR Moderator
I have sent you a Pm.
DarrenM
Done
