SuperFrustrated
Mar 31, 2023Aspirant
CAX80 no 5G...light solid
I received a CAX80 as a replacement for a bricked CAX30 due to the firmware issue.....the 5G light is lit but steady and network will not populate on any device....If I place my cell phone directly o...
Mar 31, 2023Guru - Experienced User
Does a factory reset change anything? Press the reset button for 10 seconds then release.
Has the modem worked at all since you got it from NG?
SuperFrustrated
No...I have reset the modem 5x's....been thru numerous tests with support and still...solid light but no 5g
