jiweeo
Aug 08, 2022Aspirant
CAX80 not functioning. Only the Power Light is on.
My CAX80 suddenly stoped working in a morning. Not responding at all. Only the power light is on (solid white). I tried pressing the reset button for a minute. It didn't help. I tried recoverin...
jcochems
Aug 09, 2022Aspirant
This exact issue just happened to me TODAY so I just signed into Netgear to look up warranty/support info and came across the Support Forum and this message. I work from home and was working without any issue for about four hours this morning, then suddenly my internet went out. I use Xfinity Internet service. Checked my Nighthawk router (Modal CAX80) which showed a solid white Power led, but NO other lights at all.
Paid $430 for this hardware only 8 months ago brand new from Amazon.
Tried everything mentioned in prior comments above with no change. Continuing to read this thread and saw some other messages stating to direct message two individual's at Netgear Support which I will do. I have unplugged power as well as coax cable and tried reset. No change. When plugging back in, the Power led lights up solid white and NO other lights are on. Pressing WiFi On/Off or WPS Button has no reaction at all, no lights blink or light up when pressed. Tried connecting laptop to router via direct Cat5 cable and unable to connect to router at all, not even a reply when pinging Default Gateway IP.
Jim
- FURRYe38Aug 09, 2022Guru - Experienced User
- jcochemsAug 09, 2022Aspirant
Thanks for taking the time to reply and the link Furry. That is the exact message I already came across as well before this one and so I have already gone ahead sent a PM to those two usernames just after I posted my reply here.
I really feel for all those people/posts I found for the SAME issue and modal and were just a little over a year from purhcase so were just past their warranty on a $425+ pieec of hardware. Clearly there is something not right with this modal/hardware.
Thanks
Jim
Ya unfortuneately we can't fix it out here in the field. I believe NG is aware of the issue and is trying to help all CAX80 users out. I agree, it's a spendy peice of equipment to go down unexpectedly and prematurely. Hoping NG will help you all out.
Keep on them.
Thanks
Jim
