Axl323
Jul 07, 2020Initiate
CAX80 not getting full speed
So I just got my CAX80 and it looks like it cant reach my gig speed. My computer was reaching 900+mbps with my previous wired set up on my linksys router but now it only gets 300-400mbps with the new ...
Jul 07, 2020Guru - Experienced User
What mode do you have the CAX in? Router or modem only?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- carson_adkinsJul 09, 2020Apprentice
yes i have a good quality cable its not the cables its the service or the routher itsself not being gigabit from xfinity even tho it says it is and works from xfinity
also i have just has xfinity out and checking the cables and it works fine with the xb7 router from xfinity
