Axl323
Jul 07, 2020Initiate
CAX80 not getting full speed
So I just got my CAX80 and it looks like it cant reach my gig speed. My computer was reaching 900+mbps with my previous wired set up on my linksys router but now it only gets 300-400mbps with the new ...
Jul 19, 2020Guru - Experienced User
Would you mind posting your Cable connection status results as well like I did. Would be helpful to see what yours looks like while on XF.
nsne wrote:Out of curiosity, what firmware is everyone on? I'm seeing 920 down/39 up on a 1Gig plan with Xfinity.
carson_adkins
Jul 19, 2020Apprentice
wired I am getting 900 and 38up but on wifi getting at most 300 on wifi 6 I'll post my connection stats
- nsneJul 19, 2020Virtuoso
Ah, I see. I'm unable to test WiFi 6. Won't have any compatible devices until later this year. I was testing using wired:
My setup in this test case is the following: coax to CAX80 (very short run), Cat6 cable from the CAX80's multiGig port to a 10G D-Link switch. From there, I've got a Cat6 cable running to a Mac mini (2012) using a 2.5G Ethernet adapter.
- FURRYe38Jul 19, 2020Guru - Experienced User
nsne wrote:Ah, I see. I'm unable to test WiFi 6. Won't have any compatible devices until later this year. I was testing using wired:
- carson_adkinsJul 19, 2020Apprentice
here is mine i think youve already seen it also im curious what anyones wifi 6 speeds are if you fury or anyone elses speeds on wifi 6 are
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 459 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 33 459000000 Hz -0.2 dBmV 41.7 dB 60 41 2 Locked 256 QAM 1 483000000 Hz -0.6 dBmV 41.7 dB 51 35 3 Locked 256 QAM 2 489000000 Hz -0.6 dBmV 41.6 dB 53 41 4 Locked 256 QAM 3 495000000 Hz -0.6 dBmV 41.6 dB 38 43 5 Locked 256 QAM 4 501000000 Hz -0.7 dBmV 41.4 dB 59 32 6 Locked 256 QAM 5 507000000 Hz -0.8 dBmV 41.4 dB 49 33 7 Locked 256 QAM 6 513000000 Hz -0.9 dBmV 41.4 dB 66 29 8 Locked 256 QAM 7 519000000 Hz -0.9 dBmV 41.4 dB 59 39 9 Locked 256 QAM 8 525000000 Hz -1.1 dBmV 41.3 dB 54 42 10 Locked 256 QAM 9 531000000 Hz -1.1 dBmV 41.2 dB 56 34 11 Locked 256 QAM 10 537000000 Hz -1.3 dBmV 41.2 dB 54 37 12 Locked 256 QAM 11 543000000 Hz -1.6 dBmV 41.0 dB 56 41 13 Locked 256 QAM 12 549000000 Hz -1.7 dBmV 41.0 dB 66 33 14 Locked 256 QAM 13 555000000 Hz -1.7 dBmV 41.0 dB 52 36 15 Locked 256 QAM 14 561000000 Hz -1.6 dBmV 40.9 dB 72 32 16 Locked 256 QAM 15 567000000 Hz -1.8 dBmV 40.9 dB 58 34 17 Locked 256 QAM 16 573000000 Hz -2.1 dBmV 40.7 dB 57 39 18 Locked 256 QAM 17 579000000 Hz -2.3 dBmV 40.5 dB 61 31 19 Locked 256 QAM 18 585000000 Hz -2.4 dBmV 40.5 dB 51 45 20 Locked 256 QAM 19 591000000 Hz -2.5 dBmV 40.4 dB 83 37 21 Locked 256 QAM 20 597000000 Hz -2.5 dBmV 40.4 dB 63 64 22 Locked 256 QAM 21 603000000 Hz -2.7 dBmV 40.2 dB 51 46 23 Locked 256 QAM 22 609000000 Hz -3.0 dBmV 40.1 dB 52 48 24 Locked 256 QAM 23 615000000 Hz -3.0 dBmV 40.0 dB 68 36 25 Locked 256 QAM 24 621000000 Hz -2.9 dBmV 40.1 dB 55 42 26 Locked 256 QAM 34 465000000 Hz -0.3 dBmV 41.5 dB 46 38 27 Locked 256 QAM 35 471000000 Hz -0.5 dBmV 41.5 dB 54 47 28 Locked 256 QAM 36 477000000 Hz -0.6 dBmV 41.6 dB 57 33 29 Locked 256 QAM 38 429000000 Hz 0.4 dBmV 42.2 dB 60 37 30 Locked 256 QAM 39 435000000 Hz 0.3 dBmV 42.1 dB 58 39 31 Locked 256 QAM 40 441000000 Hz -0.1 dBmV 41.8 dB 65 33 32 Locked 256 QAM 41 453000000 Hz -0.1 dBmV 41.9 dB 62 34 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 61 5120 Ksym/sec 35800000 Hz 42.3 dBmV 2 Locked ATDMA 62 5120 Ksym/sec 29400000 Hz 41.8 dBmV 3 Locked ATDMA 63 5120 Ksym/sec 23000000 Hz 40.8 dBmV 4 Locked ATDMA 1 5120 Ksym/sec 16600000 Hz 40.0 dBmV 5 Not Locked Unknown 0 0 0 0.0 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power
