AndrewD0318
Jul 02, 2023Aspirant
CAX80 Not Getting Plan Speed
I bought a CAX80 yesterday, with the hopes that the wi-fi in it would be better than the XF XB7 with the 2 GB plan. After activating the CAX80 on XF, it's falling real short of what I was getting wit...
AndrewD0318
Hi, the switch is a TrendNet TEG-S350, but looping that out, there is no change. CAX80 straight to PC is still 500-600. All cables are CAT8. Exact cables/switch/setup as with the Xfin XB7 gateway, it's just 1/3 the speed.
The wifi performance isn't bothering me as much for the moment as the LAN. Speedtest within the netgear app shows 2300D/240U. (as well as the "2.5" lit up on the front of the modem.
Actual speed tests result in 500-600 and less than 10M up.
Firmware is V2.1.5.2
Jul 02, 2023Guru - Experienced User
So you were able to see to spec speeds with same PC connected to the ISP modem?
CAT8 STP should be used.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- AndrewD0318Jul 02, 2023Aspirant
To answer your question, yes, I get the 2.2G on the xfinity gateway, direct to PC and through switch.
Connection info:
Procedure Status Comment Acquire Downstream Channel 447 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 4 447000000 Hz 0.9 dBmV 45.1 dB 0 0 2 Locked 256 QAM 1 429000000 Hz 0.9 dBmV 45.1 dB 0 0 3 Locked 256 QAM 2 435000000 Hz 0.7 dBmV 45.0 dB 0 0 4 Locked 256 QAM 3 441000000 Hz 0.8 dBmV 45.1 dB 0 0 5 Locked 256 QAM 5 453000000 Hz 1.2 dBmV 45.2 dB 0 0 6 Locked 256 QAM 6 459000000 Hz 1.2 dBmV 45.3 dB 0 0 7 Locked 256 QAM 7 465000000 Hz 1.1 dBmV 45.1 dB 0 0 8 Locked 256 QAM 8 471000000 Hz 1.1 dBmV 44.7 dB 0 0 9 Locked 256 QAM 9 477000000 Hz 1.1 dBmV 44.6 dB 0 0 10 Locked 256 QAM 10 483000000 Hz 1.3 dBmV 45.1 dB 0 0 11 Locked 256 QAM 11 489000000 Hz 1.3 dBmV 44.9 dB 0 0 12 Locked 256 QAM 12 495000000 Hz 1.5 dBmV 37.7 dB 0 0 13 Locked 256 QAM 13 501000000 Hz 1.3 dBmV 40.9 dB 0 0 14 Locked 256 QAM 14 507000000 Hz 1.5 dBmV 35.9 dB 0 0 15 Locked 256 QAM 15 513000000 Hz 1.4 dBmV 38.7 dB 0 0 16 Locked 256 QAM 16 519000000 Hz 1.6 dBmV 44.8 dB 0 0 17 Locked 256 QAM 17 525000000 Hz 1.5 dBmV 45.0 dB 0 0 18 Locked 256 QAM 18 531000000 Hz 1.8 dBmV 45.1 dB 0 0 19 Locked 256 QAM 19 537000000 Hz 1.5 dBmV 44.9 dB 0 0 20 Locked 256 QAM 20 543000000 Hz 1.6 dBmV 45.0 dB 0 0 21 Locked 256 QAM 21 549000000 Hz 1.3 dBmV 44.8 dB 0 0 22 Locked 256 QAM 22 555000000 Hz 1.2 dBmV 44.7 dB 0 0 23 Locked 256 QAM 23 561000000 Hz 1.3 dBmV 44.7 dB 0 0 24 Locked 256 QAM 24 567000000 Hz 1.4 dBmV 44.6 dB 0 0 25 Locked 256 QAM 25 573000000 Hz 1.6 dBmV 44.9 dB 0 0 26 Locked 256 QAM 26 579000000 Hz 1.7 dBmV 44.9 dB 0 0 27 Locked 256 QAM 27 585000000 Hz 1.8 dBmV 44.9 dB 0 0 28 Locked 256 QAM 28 591000000 Hz 1.8 dBmV 44.8 dB 0 0 29 Locked 256 QAM 29 597000000 Hz 1.8 dBmV 44.7 dB 0 0 30 Locked 256 QAM 30 603000000 Hz 1.6 dBmV 44.6 dB 0 0 31 Locked 256 QAM 31 609000000 Hz 1.9 dBmV 44.7 dB 0 0 32 Locked 256 QAM 32 615000000 Hz 1.5 dBmV 44.5 dB 0 0 - AndrewD0318Jul 02, 2023Aspirant
Ok, now I guess I need help on how to post the rest of the logs, I get this error: "Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."
- FURRYe38Jul 02, 2023Guru - Experienced User
Just press POST when you see that message.
Cable Connections page looks good. Power and such is with specs. Zero Correctables is good.
Post the Event Logs page.
What is the connection rate speed seen on the CAX80s WEB page under Advanced tab/Internet Port section/Show Stats/LAN port 5?
