brownbear55
Mar 07, 2023Guide
CAX80: Poor Cable Connection Status
Hi everyone. I have Xfinity's Gig speed Internet plan and recently purchased the Nighthawk CAX80. Currently, its cable connection status shows as poor. I did a quick search in the forums and I co...
- Mar 08, 2023
Your power levels are to high.
You need a 3-6db attenuator or a 3-4x splitter in line to get the power down a bit.
The power level should be between-7.5dbmv and 7.5dbmv. You're above 12.
Mar 08, 2023Guru - Experienced User
brownbear55
Mar 08, 2023Guide
By using a coaxial splitter to slightly reduce the power, would I then see increased speeds or at least in theory?
- KitsapMar 08, 2023Master
brownbear55 wrote:By using a coaxial splitter to slightly reduce the power, would I then see increased speeds or at least in theory?
You are way too hung up on throughput (speed).
If your cable input signal power levels are not within specification, the modem will not have a chance to do the job it was designed to do.
Give your modem a chance to do it's job. If you still have throughput problems, work your way downstream to find the problem.
- brownbear55Mar 09, 2023Guide
I placed an order for a 6db attenuator. It should be here within a week. I'll post results after I install it and run another diagnostic.
- KitsapMar 09, 2023Master
brownbear55 wrote:I placed an order for a 6db attenuator. It should be here within a week. I'll post results after I install it and run another diagnostic.
When the attenuator arrives, power down you modem before you connect it in line. Then power up your modem and give it time to boot and stabilize.
