brownbear55
Mar 08, 2023Guide
CAX80: Poor Cable Connection Status
Hi everyone. I have Xfinity's Gig speed Internet plan and recently purchased the Nighthawk CAX80. Currently, its cable connection status shows as poor. I did a quick search in the forums and I co...
- Mar 08, 2023
Your power levels are to high.
You need a 3-6db attenuator or a 3-4x splitter in line to get the power down a bit.
The power level should be between-7.5dbmv and 7.5dbmv. You're above 12.
brownbear55
Mar 09, 2023Guide
I placed an order for a 6db attenuator. It should be here within a week. I'll post results after I install it and run another diagnostic.
Kitsap
Mar 09, 2023Master
brownbear55 wrote:I placed an order for a 6db attenuator. It should be here within a week. I'll post results after I install it and run another diagnostic.
When the attenuator arrives, power down you modem before you connect it in line. Then power up your modem and give it time to boot and stabilize.
- brownbear55Mar 13, 2023Guide
plemans Kitsap Thank you for your contributions and input! I installed the db attenuator (powered down the modem router first) and can confirm this $9 part I purchased from Amazon resolved the poor downstream status. And to think Xfinity wanted to charge me $100.
Here are the results:
Startup Procedure Procedure Status Comment Acquire Downstream Channel 507 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 5 507000000 Hz 6.1 dBmV 41.1 dB 0 0 2 Locked 256 QAM 2 489000000 Hz 6.2 dBmV 41.1 dB 0 0 3 Locked 256 QAM 3 495000000 Hz 6.0 dBmV 41.1 dB 0 0 4 Locked 256 QAM 4 501000000 Hz 6.0 dBmV 41.1 dB 0 0 5 Locked 256 QAM 6 513000000 Hz 6.0 dBmV 41.2 dB 0 0 6 Locked 256 QAM 7 519000000 Hz 6.1 dBmV 41.4 dB 0 0 7 Locked 256 QAM 8 525000000 Hz 6.1 dBmV 41.4 dB 0 0 8 Locked 256 QAM 9 531000000 Hz 6.1 dBmV 41.5 dB 0 0 9 Locked 256 QAM 10 537000000 Hz 6.0 dBmV 41.5 dB 0 0 10 Locked 256 QAM 11 543000000 Hz 5.7 dBmV 41.5 dB 0 0 11 Locked 256 QAM 12 549000000 Hz 5.7 dBmV 41.5 dB 0 0 12 Locked 256 QAM 13 555000000 Hz 5.6 dBmV 41.5 dB 0 0 13 Locked 256 QAM 14 561000000 Hz 5.6 dBmV 41.5 dB 0 0 14 Locked 256 QAM 15 567000000 Hz 5.7 dBmV 41.9 dB 0 0 15 Locked 256 QAM 16 573000000 Hz 5.5 dBmV 41.8 dB 0 0 16 Locked 256 QAM 17 579000000 Hz 5.6 dBmV 41.9 dB 0 0 17 Locked 256 QAM 18 585000000 Hz 5.7 dBmV 41.8 dB 0 0 18 Locked 256 QAM 19 591000000 Hz 5.7 dBmV 41.9 dB 0 0 19 Locked 256 QAM 20 597000000 Hz 5.8 dBmV 42.0 dB 0 0 20 Locked 256 QAM 21 603000000 Hz 5.9 dBmV 42.1 dB 0 0 21 Locked 256 QAM 22 609000000 Hz 5.9 dBmV 42.2 dB 0 0 22 Locked 256 QAM 23 615000000 Hz 5.8 dBmV 42.2 dB 0 0 23 Locked 256 QAM 24 621000000 Hz 5.9 dBmV 42.2 dB 0 0 24 Locked 256 QAM 26 627000000 Hz 6.0 dBmV 42.2 dB 0 0 25 Locked 256 QAM 27 633000000 Hz 6.1 dBmV 42.3 dB 0 0 26 Locked 256 QAM 28 639000000 Hz 6.2 dBmV 42.3 dB 0 0 27 Locked 256 QAM 29 645000000 Hz 6.3 dBmV 42.4 dB 0 0 28 Locked 256 QAM 30 651000000 Hz 6.4 dBmV 42.4 dB 0 0 29 Locked 256 QAM 31 657000000 Hz 6.6 dBmV 42.4 dB 0 0 30 Locked 256 QAM 32 663000000 Hz 6.7 dBmV 42.5 dB 0 0 31 Locked 256 QAM 33 669000000 Hz 6.7 dBmV 42.5 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 6 5120 Ksym/sec 29200000 Hz 36.5 dBmV 2 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 36.8 dBmV 3 Locked ATDMA 7 5120 Ksym/sec 22800000 Hz 36.5 dBmV 4 Locked ATDMA 8 5120 Ksym/sec 16400000 Hz 35.8 dBmV 5 Locked ATDMA 10 1280 Ksym/sec 39600000 Hz 42.8 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 37 690000000 Hz 7.48 dBmV 41.7 dB 1108 ~ 2987 3528589 2618028 0 2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV - plemansMar 14, 2023Guru - Experienced User
Much more in line with what I'd expect or where it should be.
Hope it stays stable!
