lion123's avatar
lion123
Follower
Dec 14, 2021
CAX80 poor network status and sometimes network dropped
Hi,    Not sure if anyone has the similar issue, please check the cable connection details shown below, it keep showing poor network status and I have changed a coax wire but it is not getting bett...
  • plemans's avatar
    Dec 14, 2021
    Your right. Your logs are indicating a line issue but the cable connections page is pretty spot on for looking good.
    These types of issues are harder to track.
    If you've changed out the coax and have a direct connection coming in, then the ISP would need to check it.
