buddyb99
Apr 04, 2022Aspirant
CAX80 poor network status and sometimes network dropped
Cannot solve poor cable connection. Below is the diagnostic. Cable Connection Cancel Apply Cable Diagnostic Status: Poor Action: [Partial Service] If the Pa...
buddyb99
Apr 22, 2022Aspirant
Thanks Plemans, My gateway is connected directly to the coaxial cable coming from the box outside my building and I don't have any amplifiers, signal attenuators, or splitters from the coax. I've had RCN come out and check the line from outside up to my gateway and they cannot find any issues with the line (of course they are not well trained). I'm really stumped as to what the issue could be. Any other ideas or tests I can run?
Apr 22, 2022Guru - Experienced User
Are you having issues with your connection other than the unlocked channels?
Is it dropping?
