HardFart
Jan 30, 2021Tutor
CAX80 Port forwarding broke
Recently I discovered that I cannot setup any port forwarding on my CAX80. When I try, I get this error message; The specified port(s) are being used by other configurations. Please check your ...
- Jan 31, 2021
UPDATE: I solved the issue
When I initially configured the CAX80 I enabled the use of the built-in DHCP server to provide IP addresses beginning at 10.0.0.2 through 10.0.0.254. During this time of its use, I enabled the Port Forwarding option to a system with IP address 10.0.0.123 to test incoming conenctivity to a webserver I was hosting. After I confirmed it worked, I removed the port forwarding because I was not happy about the inability to restrict incoming IP addresses.As I proceeded to statically set IP addresses to a majority of systems in my home network, I subsequently modifed the range of IP addresses the DHCP server would assign to begin with .200 (through .254). Later, I decided to disable the use of the DHCP server entirely. However despite the option being greyed out indicating it was not being used, the reference to the beginning IP address 10.0.0.200 remained visible, though it too was greyed out.
Curious, I enabled the DHCP server, modified the beginning IP address to 10.0.0.2, saved the change, then disabled the use of the DHCP server. Once this was done, I was able to add the port forwarding rule.
To the OP, go take a look at the settings of the DHCP server. I suspect you might have been bit like I was.
commodon
Jan 31, 2021Star
klimchuk
Feb 08, 2021Aspirant
Unfortunatley offered solution did not work for me. At some point I was not able to add new port forwarding but old ones were fine.
After flipping DHCP switch old ones are gone too! Now I'm back to square one
- j0ls0nFeb 19, 2021Aspirant
Same here. I have most everything turned off and now can't set any forwarding. I had a rule set here last week but now it's broken. What the crap?!!
(also why is the CAX80 not an available model above?)
