jbtaco2002
Sep 15, 2020Star
CAX80 problems
When you buy one of these at this price point, there's a certain expectation that it will just work. set it up once and pretty much forget about it. That has NOT been the case for me as pretty m...
Sep 15, 2020Guru - Experienced User
Do you have a screen snip of the cable connections page and the modem logs?
If the wifi is connected but showing "connected, no internet" and you don't have an address from the ISP, then it could be a modem/isp/line issue.
jbtaco2002
Sep 15, 2020Star
snip attached, what from the logs would be relevant or helpful? i attached one entry that's concerning to me since it recurs every 15 minutes or so...
thanks for your help!
- jbtaco2002Sep 15, 2020Star
the other snip
EVENT LOGS:
Time Priority Description Tue Sep 15 10:13:35 2020 Warning (5) Dynamic Range Window violation Tue Sep 15 10:13:35 2020 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 19:00:04 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 18:16:07 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: 2; New Profile: 2 3.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:26:01 2020 Warning (5) Dynamic Range Window violation Mon Sep 14 17:26:01 2020 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:25:58 2020 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:25:58 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2; New Profile: 2.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:14:19 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:13:16 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Mon Sep 14 17:13:16 2020 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:53 1970 Notice (6) Honoring MDD; IP provisioning mode = IPv4 Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 9 06:48:18 2020 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Sep 8 21:04:34 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:52 1970 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:07:34 2020 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:07:28 2020 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:07:26 2020 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:02:35 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:01:57 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:01:35 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:01:09 2020 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 22:01:08 2020 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:48:32 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:01:00 1970 Critical (3) DHCP FAILED - Discover sent, no offer received;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:53 1970 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:39:55 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:19:58 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:19:56 2020 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:10:52 2020 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 21:05:27 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; Sun Sep 6 20:58:44 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; - plemansSep 15, 2020Guru - Experienced User
t3 errors and the dynamic window violation tend to indicate a line issue.
The 2 other screen shots weren't the cable connections page. When you first log into the CAX80 from your computer, click on the internet/cable connection icon
if there's any splitters, attenuators, amplifiers in line, I'd remove them.
