jbtaco2002
Sep 15, 2020Star
CAX80 problems
When you buy one of these at this price point, there's a certain expectation that it will just work. set it up once and pretty much forget about it. That has NOT been the case for me as pretty m...
jbtaco2002
Sep 15, 2020Star
the other snip
jbtaco2002
Sep 15, 2020Star
EVENT LOGS:
| Time | Priority | Description |
| Tue Sep 15 10:13:35 2020 | Warning (5) | Dynamic Range Window violation |
| Tue Sep 15 10:13:35 2020 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 19:00:04 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 18:16:07 2020 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: 2; New Profile: 2 3.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:26:01 2020 | Warning (5) | Dynamic Range Window violation |
| Mon Sep 14 17:26:01 2020 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:25:58 2020 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:25:58 2020 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2; New Profile: 2.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:14:19 2020 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:13:16 2020 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Mon Sep 14 17:13:16 2020 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:53 1970 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Thu Jan 1 00:00:44 1970 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Wed Sep 9 06:48:18 2020 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Tue Sep 8 21:04:34 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:52 1970 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:07:34 2020 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:07:28 2020 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:07:26 2020 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:02:35 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:01:57 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:01:35 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:01:09 2020 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 22:01:08 2020 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:48:32 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:01:00 1970 | Critical (3) | DHCP FAILED - Discover sent, no offer received;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:53 1970 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:39:55 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:19:58 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:19:56 2020 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:10:52 2020 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 21:05:27 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
| Sun Sep 6 20:58:44 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3e:8a:a0;CMTS-MAC=00:38:df:9a:01:d1;CM-QOS=1.1;CM-VER=3.1; |
