jbtaco2002
Sep 15, 2020Star
CAX80 problems
When you buy one of these at this price point, there's a certain expectation that it will just work. set it up once and pretty much forget about it. That has NOT been the case for me as pretty m...
dadabunchie
Nov 13, 2020Aspirant
FURRYe38 wrote:
dadabunchie wrote:Fundamentally I think there are things wrong with this unit, 1) DHCP server hangs, What FW are you using?
Something I have not need since getting mine earlier this year.
2) Entire unit reboots when ISP Carrier drops Modem signal,
This is by design. I asked about this. :smileyembarrassed:
3) Post reboot the modem randomly resets all settings to default,
I saw this as well and should have been fixed.
4) Logs are lost after reboot/reset. Something I'm not sure about if the logs are kept after a reboot or even if you enable the logs for 5 secnds then select save logs again may capture the logs. I believe most routers and modems clear the logs on any reboot though.
my 2 cents
The unit is on FW V1.1.0.41 and cable FW V1.02.08
my 2 cents
