jbtaco2002
Sep 15, 2020Star
CAX80 problems
When you buy one of these at this price point, there's a certain expectation that it will just work. set it up once and pretty much forget about it. That has NOT been the case for me as pretty m...
trpeople
Nov 13, 2020Guide
If you disable the AX feature, you might as well just return the device and get a WI-FI AC device and save the money.
Here's the difference of Wi-Fi 5 (AC) vs Wi-Fi 6 (AX) - https://youtu.be/KufwPgJkUjw
Nov 13, 2020Guru - Experienced User
The suggestion of disabling of AX mode on the modem is a troubleshooting step to see if the changes the interaction behavior between the modem and the wifi device. Some devices have some problems with AX mode being enabled, AX supporting or not. So temporarily disabling AX mode on the modem might help with some difference experiences and seems to be some sort of issue with one specific brand and model of Samsung devices. One does not have to keep AX mode disabled ALL the time.
Users are encouraged to contact both NG and Samsung regarding there experiences and hopefully some here, something will get fixed.
