jbtaco2002
Sep 15, 2020Star
CAX80 problems
When you buy one of these at this price point, there's a certain expectation that it will just work. set it up once and pretty much forget about it. That has NOT been the case for me as pretty m...
Nov 18, 2020Guru - Experienced User
Has anyone seen a new version of FW on there modems? v2.1.1.4?
Power OFF your CAX80 for 1 minute then back on...
Lurksalot
Nov 21, 2020Apprentice
I don't think the CAX80 FW update is approved by Cox and other ISP's yet.
Thanks.
- FURRYe38Nov 21, 2020Guru - Experienced User
Thats only for the modem portion. For CAX there is a router portion that seems to be under NGs control.
- LurksalotNov 21, 2020Apprentice
The top of the link states the following, emphasis added:
"You cannot manually update your NETGEAR cable modem or modem router’s firmware.
NETGEAR provides your ISP with the latest firmware and your ISP updates your firmware.
If your firmware is out of date, contact your Internet Service Provider (ISP) for assistance."Thanks
The CAX80 is the only modem that the router portion can be udpated by a user. The modem portion is still pushed by the ISP.
Thanks.
