TwoTabs
Jan 13, 2022Apprentice
CAX80 Questions after install
I got my CAX80 Yesterday and everything installed fine. Modem Activated with Spectrum without any issues. Connection is Rock Solid form Wired to Wifi. Some things i noticed when trying to do a fe...
Jan 13, 2022Guru - Experienced User
Most of the time uPnP would be disabled if you set up any PF rules.
Most of the time uPnP should work enabled with out having to disable it or setup any PF rules...Possible uPnP may have got in a bad state while trying to get the cameras connected.
You don't see any drop down menu on the far right side of the IPv6 menu to disable IPv6 or maybe a check box?
