mesprime
Aug 17, 2022Aspirant
CAX80 Restart loop
 Modem/router constantly reboots. After a restart, it will establish sync with Xfinity network.  Xfinity support can see the Modem briefly and from their side they say signals look fine, but after abo...
- Aug 17, 2022How long have you had the modem for? Is this new issue that just appeared? Something you may need to contact NG support about:
Aug 17, 2022Guru - Experienced User
mesprime
I just opened a hardware support case with Netgear. I have only had it just under 6 months. The problem occurred 3 days ago just out of the blue. I was streaming Youtube and lost Internet and assumed it was Xfinity but after spending an hour with their level 2 support we agreed it was most likely an issue with the Netgear and swapped to my old equipment which came right up.
Thanks for the assist though! I do appreciate it
- FURRYe38Aug 17, 2022Guru - Experienced UserOk, I would send the forum moderators listed here a PM as well: Seems to be some modems going down unexpectedly. If you get an RMA, please come back and let us know how the new one works...should work after that.
