mdegrande30
Dec 20, 2020Follower
CAX80 Router firmware 2.1.1.4 update fails
I just installed this CAX80 modem/router a few days ago and it has the notifacation of new firmware on home screen, but everytime I try to update the firmware it starts the action like it is download...
Dec 20, 2020Guru - Experienced User
Try powering OFF The CAX80 for 1 minute then back on. Besure only 1 wired PC is connected to the CAX. Disconnect all other devices. Use IE11, Edge or Firefox to try and trigger the FW update.
Try a factory reset on the CAX 80 and setup from scratch then first thing is to try the FW udpate.
You might contact CC or NG and ask about this...
