My_Username
Jun 12, 2022Apprentice
CAX80 running FW 2.1.3.7 tells me Router Firmware Update is Available - but it isn't
The message appears at the top of the web interface. The CAX80 checks for an update when I click in the message but there is never one available. 2.1.3.7 is claimed to me the latest on Netgears site....
My_Username
2.1.3.7 as per post title.
My_Username
Jun 13, 2022Apprentice
- KitsapJun 13, 2022Master
It appears 2.1.3.7 is the most recent for the router (RG) section of your device.
The screen snip you posted indicates no new update is available. This is consistent with the Netgear information at the link above.
- My_UsernameJun 14, 2022Apprentice
A flag appears at the top of the screen telling me me a firmware update is available. It is clearly visible in the posted screen snip.
When I check for that update under Advanced/Administration/Router Update I am told no update is available.
Something is screwed up, how unusual?
- FURRYe38Jun 15, 2022Guru - Experienced User
What happens if you power OFF the modem for 1 minute then back ON?
Might try a factory reset and setup from scratch and see if this clears the FW notification on the web page.
