afitz485
Jul 10, 2022Tutor
CAX80 security vulnerabilities
I am considering the CAX80 as my new modem to work with Xfinity's internet access. I have been unable to find information on whether this modem/router has the Cable Haunt vulnerability or not. ...
afitz485
Jul 11, 2022Tutor
I have not been able to find any information on whether the CAX80 is affected by Cable Haunt. This is a pretty serious vulnerability. Has anyone contacted Netgear or their ISP providers regarding this flaw in their cable modems?
Thanks.
Jul 11, 2022Guru - Experienced User
You might contact your ISP and see. Might check DSLReports.com as well. Though I haven't see much regarding that there. Only one item was the intel chip set problem found on Intel based modems years ago. This Cable haunt is two years old. Haven't seen much or any activity on it. I've had my CAX80 online for a couple of years. Recently put it back online in modem mode.
- afitz485Jul 12, 2022Tutor
Cable Haunt is 2yrs old - but not that old to have nothing on the web regarding the ISP providers & modem manufacturers response to it. At the very least I expected the companies to address the vulnerability with a firmware version that has the fix.
Otherwise, sounds like a good piece of hardware.
