arch1mede
Apr 04, 2023Aspirant
CAX80 shows Cancel/Apply constantly in the admin page
I was wondering if anyone else was experiencing this. I accessed the admin page, normally the Cancel/Apply buttons do not appear till you want to make a change however they show up all of the time. ...
Apr 04, 2023Guru - Experienced User
What ISP are you with?
What FW is loaded on the CAX80.
Do you have a screen capture of this that you can post here?
What browser are you using?
Normally any items on the cable connections status page are not user changeable. Changes would come in from the ISP on the modem side.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
arch1mede
What ISP are you with? Not sure why the ISP matters, this is going directly to the admin page on the lan.
What FW is loaded on the CAX80. The latest 2.1.5.2
Do you have a screen capture of this that you can post here? I donno if that would help, I click on anything in the admin page and I see a Cancel/Apply button in the lower right, clicking on it produces either a 404 error or nothing happens and the screen blinks and goes back to what it was before.
What browser are you using? Chrome, Safari, Firefox, cleared cache
Normally any items on the cable connections status page are not user changeable. Changes would come in from the ISP on the modem side. The admin page comes from the isp?
- FURRYe38Apr 05, 2023Guru - Experienced User
Does this happen after you perform a factory reset and setup from scratch?
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
