jesmith602
Apr 02, 2021Apprentice
CAX80 Speed Issues
I am unable to get my CAX80 faster than 200 down on a wired or wireless connection. I have Cox Gigablast No splitters, amplifiers, or attenuators in line. Using RG6. CAX80 is in router mode. Th...
jesmith602
Yes, I've tested with Ookla using two different laptops connected with CAT6.
Apr 02, 2021Guru - Experienced User
Is Armor enabled by chance?
Anything running on the PCs what could slow down speed tests?
Try a factory reset and setup from scratch then run a speed test again?
