Talon2020
Jan 01, 2021Aspirant
CAX80 Stuck at 100mbps when using Multigig Port for Ethernet
Just started yesterday, my CAX80 multigig port no longer works beyond 100mbps. Tried with 2 different NIC on my motherboard, both produce same result. Also switched my ethernet cable and same results...
Talon2020
Jan 03, 2021Aspirant
Network Card: Aquantia AQtion AQC107 10Gbit Network Adapter
Network Card: Intel I225-V Ethernet Controller
Both exhibit exactly the same issue of max 100mbps connections and both were working 100% until just a few days ago. It started out of nowhere, no Windows or drivers updates were applied or changed. I verified the driver version and even tried to clean reinstall the driver. Tried different cables, and issue persists.
Both network adapters work 100% at 1000mbps link when switching to the LAN1 port. However that isn't a "fix" as the Multi-gig port should work as intended like it did before.
Does it sound like I need to start an RMA with Netgear?
Jan 03, 2021Guru - Experienced User
I would yes. Keep us posted on how it goes.
- Talon2020Jan 12, 2021Aspirant
Did the RMA with Netgear over the phone. Took about 20 minutes of speaking to their intial adviser and letting them know what I had done on my end to trouble shoot the modem/router and after a brief hold so they could confirm with their higher level support they issued me an RMA.
I took the advanced RMA option which I was thankful they had since I need the modem/router for work and didn't want to drag out an old device and go through the process of activating and reseting my home network. Took a couple days and got my new unit. After some initial setup issues with Xfinity not being able to activate the modem properly it finally worked (took 4 activation signals from Xfinity). I've been using it for about a week now and everything has been great. Multigig Port working as it should. I really hope this unit lasts a lot longer than the first unit and hopefully I just got a lemon.
- FURRYe38Jan 12, 2021Guru - Experienced User
Thanks for letting us know. Hope it works well too. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
