CitizenF's avatar
CitizenF
Follower
Jul 30, 2022
CAX80 Stuck at password reset on login
Hello, all of a sudden I cannot login to my cax80 any more. I go to the typical 192.168.1.1 ip and it brings up my login screen, i login and it takes me straight to a password reset screen, I enter all info it resets and when I click login it comes right back up. Tried holding down reset for 10 sec, it reset and still does the same thing...out of warranty already
  • FURRYe38's avatar
    Be sure to clear all browser caches. Close the browser then re-open the browser.
    Try a different browser, MS Edge or Firefox.
  • plemans's avatar
    Make sure when setting up a new password that you meet the minimum requirements.
    1 Upper Case
    1 Lower Case
    1 Number
    1 Special Character
