jemartin1979
Feb 24, 2022Aspirant
CAX80 Stuck in Modem Only Mode
Hi, I have a Nighthawk CAX80 that is stuck in Modem only mode. I am unable to access the user interface of the Modem in any way to change it back. The factory reset button is also not working. ...
jemartin1979
I have tried accessing 192.168.1.1 (this is the devices default), with no luck. I have tried accessing 192.18.0.1 (what it was set to before this started happening), with no luck. Netgear tech support had me try 192.18.100.1, with no luck. All were done with my PC connected directly to the CAX80 via Ethernet cable. We even tried the resets a few times with no devices connected to the CAX80. Even tried with the COAX removed. etc... No luck. They even had me try manually setting my PC IP address for each of them with no luck. They had me try just a short press of the rest button, a 5 second press, a 7 second press and a 10 second press. All many time with no luck. All of which I had tried numerous times with no luck. Lastly they had me try the 30/30/30, again with no luck. Nothing will kick the CAX80 out of router only mode. It also cannot be accessed via the app. The device does not output any wifi signals. Once the device completes boot up, the only light that is on is the power light. The only way I can access the internet with more than 1 device is to connect another wifi router to the WAN port. All indicating it is still in modem only mode.
jemartin1979
Sorry, that last comment should have read 192.168.0.1 and 192.168.100.1.
My irritation level is through the roof with this high-dollar brand new modem and I forgot to proofread.
- FURRYe38Feb 25, 2022Guru - Experienced User
Can these resets are done with out the coax cable connected?
Have never seen this were the reset isn't working on this modem.
I recommend you contact NG support and ask for an RMA.
- jemartin1979Feb 25, 2022AspirantYes I did all resets with and without coax connected. I am just returning to Amazon for replacement. Easier process. And I don't have to send this one back until I get the new one. At least this one works in modem only mode still so I'm not without internet.
First thing you might try is set modem only on new unit, then after it's in modem only, try to set it back to gateway mode using the UI.
