bilal_ahmed
Jul 12, 2023Aspirant
CAX80 Unable to connect to online game servers
I am having trouble connecting to Call of Duty servers. I have tried port warding, changing DNS, and disabling DoS protection all in the router settings but nothing seems to work. Using a VPN solves ...
Jul 12, 2023Guru - Experienced User
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Power on the UP Side is low, something to ask the ISP to see if they can raise it some.
What game services are you connected too?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- bilal_ahmedJul 12, 2023Aspirant
Firmware Version V2.1.5.2 Time Priority Description Wed Jul 12 11:26:17 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Wed Jul 12 11:25:51 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:52 1970 Notice (6) Honoring MDD; IP provisioning mode = IPv6 Thu Jan 1 00:00:43 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Jul 12 00:00:10 2023 Critical (3) Resetting the cable modem due to docsDevResetNow Mon Jul 3 08:52:11 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:52:06 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:54 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:53 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:53 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:52 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:11 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Mon Jul 3 08:51:09 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:43 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Jun 26 16:08:16 2023 Critical (3) Resetting the cable modem due to docsDevResetNow Sat Jun 24 15:22:43 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:22:38 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:22:38 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:22:37 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:22:02 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:21:57 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:21:54 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:16:20 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:16:16 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:09:36 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:09:31 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:09:29 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:09:28 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:08:46 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:08:39 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 15:08:36 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:56 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:51 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:40 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:40 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:40 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:39 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:59:04 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:58:58 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; Sat Jun 24 14:58:54 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:2a:18;CMTS-MAC=00:90:f0:60:05:00;CM-QOS=1.1;CM-VER=3.1; A factory reset has not been done. I am using Steam to launch Call of Duty.
- FURRYe38Jul 12, 2023Guru - Experienced User
See lots of Criticals that indicated a signal problem on the ISP side of the modem. ISP should review and resolve these and if Warnings or Errors are seen in the logs as well.
- KitsapJul 12, 2023Master
Do you have any splitters, amplifiers, or filters in the coax line upstream of your CAX80?
