hellotherelol
Nov 12, 2022Aspirant
CAX80 update issues
Hi, I have a Netgear CAX80 connected via comcast. I have downloaded the recently released 2.1.5.2 firmware in order to upgrade my router from 2.1.4.2, but every time I try, it says that the firmware ...
- Nov 14, 2022
Try the link again.
Nov 14, 2022Guru - Experienced User
Try the link again.
hellotherelol
Nov 14, 2022Aspirant
The new firmware file seems to have worked, I am running firmware 2.1.5.2 now.
I do agree though, it is a bit wierd how its still in a rar
thanks!
- FURRYe38Nov 14, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - WillePNov 14, 2022AspirantI’m still having the issue which downloads as a rar file and not bin
Download the .zip file. unpack the .zip file. Then unpack the .rar file to reveal the .bin file. Do NOT attempt to unpack or open the .bin file. Just use the modems web page to send the .bin file to the modem using a wired PC and web browser.
