titanicnut
Feb 06, 2023Star
CAX80 Uploading Issues
This is our 2nd Nighthawk CAX80 … just replaced it yesterday. We are still having the same issues as before. Comcast has been out to check wiring and it’s all good. I have a main channel on smart c...
Feb 07, 2023Guru - Experienced User
- titanicnutFeb 07, 2023StarFirmware 2.1.5.2
- FURRYe38Feb 07, 2023Guru - Experienced User
How do you have the Basic and Advanced WiFi Settings configured on the modem?
Is Smart Connect, AX mode and OFDMA enabled?What channels are being used?
Any Wifi Neighbors near by? If so, how many
Any other wifi broadcast devices near by?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- titanicnutFeb 07, 2023StarYes we have neighbors as we’re in townhomes. They’re 3 other families in our building block with 4 families across from us and 4 across from them, so forth and so on.
I have no idea who uses wifi or has broadcast devices. I’m sure some or all do.
