titanicnut
Feb 07, 2023Star
CAX80 Uploading Issues
This is our 2nd Nighthawk CAX80 … just replaced it yesterday. We are still having the same issues as before. Comcast has been out to check wiring and it’s all good. I have a main channel on smart c...
Feb 07, 2023Guru - Experienced User
How do you have the Basic and Advanced WiFi Settings configured on the modem?
Is Smart Connect, AX mode and OFDMA enabled?
What channels are being used?
Any Wifi Neighbors near by? If so, how many
Any other wifi broadcast devices near by?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
titanicnut
Feb 07, 2023Star
Yes we have neighbors as we’re in townhomes. They’re 3 other families in our building block with 4 families across from us and 4 across from them, so forth and so on.
I have no idea who uses wifi or has broadcast devices. I’m sure some or all do.
- FURRYe38Feb 07, 2023Guru - Experienced User
Lets set manual channels 1 on 2.4Ghz and 40 on 5Ghz.
Take the check mark out of the Enable AX and Enable 20/40Mhz Coexistence check boxes.
Set Transmit Power to 50% on both 2.4Ghz and 5Ghz.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerWhat devices are you connecting and using to upload data?
