Swol
Jun 25, 2024Follower
CAX80 WIFI connectivity issues with manual button
Good day, I have a Night Hawk CAX80 that I have been having issues with. I mainly use ethernet for all my connections but here and there I will use the WIFI. I use the manual button to turn on and o...
Jun 25, 2024Guru - Experienced User
What model phone are you using? iOS version?
Is Smart Connect and IPv6 enabled or disabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
