KasarIG
May 06, 2021Aspirant
CAX80 WiFi Network resetting
Hello, I have a CAX80 Cable Nighthawk router that we bought about a year ago. (Hardware version: 1.01, Firmware: 2.1.1.4, Cable Firmware:1.02.08 are up-to-date) It has worked great, solely using Wi...
May 07, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page and the event logs?
I've seen ISP's trigger a new firmware install/reset process.
KasarIG
May 08, 2021Aspirant
plemans I just found where the event log is, but it only goes back 6 hours or so to this morning... If this happens again I'll grab the info from it. I've included a screenshot of the cable connections page. Everything past Channel 6 is "Not locked" showing the same information,
- plemansMay 08, 2021Guru - Experienced User
photos have to be approved by a moderator. you can click on choose file and add it th at way
