KasarIG
May 06, 2021Aspirant
CAX80 WiFi Network resetting
Hello, I have a CAX80 Cable Nighthawk router that we bought about a year ago. (Hardware version: 1.01, Firmware: 2.1.1.4, Cable Firmware:1.02.08 are up-to-date) It has worked great, solely using Wi...
May 10, 2021Guru - Experienced User
You should save a back up configuration to file for safe keeping. Saves tine if a reset is needed.
