Stew1216
Dec 21, 2020Aspirant
CAX80 Wired much slower than WIFI
I get over 350Mps on my wifi however when I connect directly to the CAX80 modem/router I only get 85-90 Mps. I am connecting with a Cat6 cable which is not defective. I also have Cat 6 wired in the...
Dec 21, 2020Guru - Experienced User
And you tried a different wired PC to compare the wired results with?
What FW version is currently loaded on the CAX80?
Stew1216
Dec 22, 2020Aspirant
Yes I have tried 2 separate PC's. My firmware is V2.1.1.4 which is says is up to date.
- FURRYe38Dec 22, 2020Guru - Experienced User
Using good quality LAN cables? CAT6 is recommended.
Seeting 1000Mpbs connection rates on the wired adapter status on the PCs network adapter?
And nothing else is happening on the network, like steaming or gaming when your testing this? If so, sounds like something with the LAN or WAN to LAN portion of this modem needs to be checked out by NG support. I'd ask for additional help and information regarding this. Ask about an RMA if needed.
