Retired_Member
Aug 03, 2022CAX80 Wireless mode settings
Greetings, CAX80, why is the wireless setting 2.4 GHz mode set to 600Mbps? Can I change the mode? The wireless in setup mode is set as up to 1200 Mbps. Thanks, Louf
Aug 03, 2022Guru - Experienced User
What browser are you using?
Is Smart Connect enabled? Try disabling SC?
Retired_Member
Aug 04, 2022Thanks FURRYe38, Firmware V2.1.3.7 and Firefox 103.0.1 64bit. I'll try disabling SC. Regards, Louf
- FURRYe38Aug 04, 2022Guru - Experienced User
đ
