mleone
May 15, 2024Aspirant
CAX80 Wireless Settings Wont Load
Using the admin portal in the browser, I can't seem to load the Basic->Wireless and Advanced->Setup->Wireless Setup pages. I've tried from Firefox, Chrome, and Edge on my desktop. I've also tried fro...
May 16, 2024Guru - Experienced User
Pressing the reset button in back for 15 seconds then release and then waiting for the modem to come to a partial ready then accessing the modems setup wizard page at 192.168.1.1 and walking thru this routine can't get the wireless settings to load in the web page?
Be sure to clear out all web browser caches before starting this. MS Edge browser should work the best. Make sure it's fully updated prior.
mleone
May 16, 2024Aspirant
Edge is up to date and cache was cleared between attempts to get the page to load and still no luck. Any other ideas?
I have also tried loading the page over a wired connection instead of over wireless and that didn't help either đ
- FURRYe38May 16, 2024Guru - Experienced User
Does this happen with a different PC as well?
