mleone
May 15, 2024Aspirant
CAX80 Wireless Settings Wont Load
Using the admin portal in the browser, I can't seem to load the Basic->Wireless and Advanced->Setup->Wireless Setup pages. I've tried from Firefox, Chrome, and Edge on my desktop. I've also tried fro...
mleone
May 16, 2024Aspirant
Edge is up to date and cache was cleared between attempts to get the page to load and still no luck. Any other ideas?
I have also tried loading the page over a wired connection instead of over wireless and that didn't help either 😞
May 16, 2024Guru - Experienced User
Does this happen with a different PC as well?
- mleoneMay 16, 2024AspirantI had tried it from both Firefox and chrome on my phone, though I can't remember if it was before or after I did the factory reset. I'll give that another try tonight.
- FURRYe38May 16, 2024Guru - Experienced User
Lets try from a PC or laptop if you have one.
- mleoneMay 16, 2024AspirantSorry, should have clarified. When I tried chrome/Firefox/edge before & after the factory reset, it was from my desktop. Only tried it from chrome & Firefox on my phone once, so I'll retry that tonight in case I only did it before the reset.
