Washutech's avatar
Washutech
CAX80 with a gigabit switch
I just purchased the CAX80 and a Tenda TEG1016M 16 port gigabit switch and when I have a wired item in the switch sometimes the devices can't connect.
  • FURRYe38's avatar
    Do you have the switch connected to the 1Gb or MultiGb port? 1Gb port would be recommended.
    What CAT# cables are you using? CAT6 is recommended.
    Try a different brand switch. NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches.
    HP switches are connected behind my CAX80 when in router mode. I have tested NG GS series and they work as well.
