WildcatTM
Jul 10, 2021Aspirant
CAX80 with Verizon FIOS?
Greetings. So I recently moved from Spectrum to FIOS. I really trying to figure out a way to use my modem instead of Verizon, particularly not as a gateway. Do forgive me if I'm butchering any ter...
Jul 11, 2021Guru - Experienced User
There's not a way.
the older combo devices had a workaround you could use but I haven't seen it successfully used on the CAX versions.
You can always read through and try but it might be time to see the device and buy just a router only device.
antinode
Jul 11, 2021Guru
> [...] Does that sound right?
No, but the conclusion is right. If you have an ONT with an Ethernet
port, then you can't use a CAX80 as a router because it lacks an
Ethernet WAN/Internet port.
> the older combo devices had a workaround you could use [...]
Not really. As it says there, that scheme gives you a wireless
access point, not a full-function router.
