longer23's avatar
longer23
CAX80 with Xfinity wifi texting failing
I've been dealing with this problem for the longest time about a year now and now I'm back on the forums trying to figure this out. I've actually ran across the same problem you are experiencing when...
  • longer23's avatar
    longer23
    Mar 03, 2024
    problem is now solved with the custom firmware provided from Netgear support. you can play with all the settings you want but you will never fix these bugs with their latest firmware that is posted on their site. it's not the internet provider, its not your phone or laptop, not the cables being used, or the setting configuration used in the modem but their latest firmware itself version 2.1.5.2.
